Re: Replacing Cast Iron Toilet Flange
Posted by hj on February 14, 2004 at 18:28:02:
In response to Re: Replacing Cast Iron Toilet Flange
1. Yes. 1a. No. 2. No. 3. No. 4. Yes. It is very easy for him and will only take a few minutes.: Hello, : I have a 40 year old house with cast iron DWV pipes. I am currently remodelling the bathrooms (1.5 baths). When removing the linoleum I discovered the subflooring was water damaged, so I am planning to replace. Is the correct procedure to (1) break out the old cast iron flange, (2) remove/replace subfloor, (3) install new flange? : A few more questions - : 1. when breaking out the cast iron flange, will the lead/oakum seal come out cleanly? is it tricky to remove? : 2. should I consider replacing the cast iron flange with PVC flange and adapter instead? : 3. should I consider replacing the entire main drain with PVC? : 4. should I leave the cast iron work to a professional? : Thanks
