| Posted by hj on February 14, 2004 at 18:18:23: | |
| In response to Re: Water Heater Noises | |
It is just mineral buildup on the element. Eventually it will cause the element to burn out and then you will replace it. : My water heater makes a high-pitched noise similar to a teapot whenever I run hot water. What could it be and does it require immediate attention?
| There are none. |
