Re: mobile home-water line problem
Posted by Deb on February 14, 2004 at 15:53:44:
In response to Re: mobile home-water line problem
: recently moved mobile home 16X56, hooked up water line as it was when moved, now...i have no water in either bathroom sinks, and no water in either toilets, and also only have hot water to washer...no cold water there now.....what have i done wrong here? can someone help me?
If all the valves are fully open, my first guess would be debris in the lines (everywhere). It happens alot in mobile homes with galv lines that have been moved. Remove all the aerators and see if that helps. Shut off the water to the washer and remove the hose and see if the screen is clogged. The ballcock assemblies for toilets have very small holes that can get clogged. You can disassemble and flush or replace with a Fluidmaster 400A.
Deb
The Pipewench
Replies to this post
There are none.
