Re: mobile home-water line problem
Posted by Gary Slusser on February 14, 2004 at 13:42:28:
In response to Re: mobile home-water line problem
: recently moved mobile home 16X56, hooked up water line as it was when moved, now...i have no water in either bathroom sinks, and no water in either toilets, and also only have hot water to cold water there now.....what have i done wrong here? can someone help me?
It sounds as if you have a valve still shut. Gate valves tend to break in the shut position any yet they look like they are opening/shutting. That's due to the gate falling off the stem and the stem still rotates with the handle. Otherwise, do you have the pump turned on and is it running? Did you prime it if needed?
Quality Water Associates
Replies to this post
There are none.
