Re: Leaking Outdoor Faucet
Posted by e-plumber on February 13, 2004 at 18:19:03:
In response to Re: Leaking Outdoor Faucet
: I have a Mansfield outdoor faucet that is leaking. I assume all it needs is a new washer. How do I go about replacing the washer?
If the spout is dripping -
You would need to shut the water off inside the house first of course. Remove the handle, then unscrew the bonnett nut from the faucet body. If it is a frost free bibb, or a regular hose bibb, simply replace the washer.
Good Luck. e-plumber
Replies to this post
There are none.
