Re: Delta Monitor Shower Leaking By
Posted by Jeff on February 13, 2004 at 14:42:20:
In response to Re: Delta Monitor Shower Leaking By
: : I have a Delta Monitor, single arm shower. Last night, when I turned the shower off it began to leak by pretty badly. Do you think it's the washers inside the handle? Is there a screw that will allow me to take the handle off to get to the washers? I looked but it appears that if there is a screw in the hole, it is stripped. I can't seem to get the handle off.
: : Thanks.
: Reply:
: The screw that you believe is stripped may be an allen screw. You can always go to Delta's website, they have faucet explosions that show how each of the Monitor faucets are taken apart and repaired.
: Good Luck. e-plumber
You were exactly right. I figured it out and managed to repair the valve this morning. Thanks for helping.
Replies to this post
There are none.
