Re: waste pipe leak under tub
Posted by e-plumber on February 12, 2004 at 21:08:31:
In response to Re: waste pipe leak under tub
: i'm in through the wall in the room next door. i've got an obvious drip at the joint on the waste pipe. what is the best way to go here? replace the entire waste overflow system? or can i get away with doing something less? i do want a long-term fix.
: thanks for the help!
Reply:
It depends on what exactly is leaking on which way to approach the repair.
Is it possible to tighten a joint and stop the leak?
e-plumber
Replies to this post
There are none.
