| Posted by hj on February 12, 2004 at 19:02:35: | |
| In response to Re: Delta Monitor Shower Leaking By | |
There are three different styles of Monitor valve. Which do you have/ : I have a Delta Monitor, single arm shower. Last night, when I turned the shower off it began to leak by pretty badly. Do you think it's the washers inside the handle? Is there a screw that will allow me to take the handle off to get to the washers? I looked but it appears that if there is a screw in the hole, it is stripped. I can't seem to get the handle off. : Thanks.
