| Posted by jimbo on February 11, 2004 at 22:13:52: | |
| In response to normal | |
:All softeners will have a pressure drop across the unit. The tech. data for your unit should give you this information. Since you are on a somewhat lower pressure than someone on a city main, you would notice a 6 or 7 pound drop. Is your softener system sized properly for the gallons per minute that you typically use? |
| There are none. |
