Re: Garbage disposal backup
Posted by e-plumber on February 11, 2004 at 19:52:51:
In response to Re: Garbage disposal backup
: I was running my garbage disposal quite a bit this morning when all of a sudden water came shooting out the drain on the other side of the sink. (I have a double sink) I shut it off right away. It smelled like a sewer, so I put some vinegar and pine sol down it. Then I ran it again. It backed up a little into the other sink but I ran it one more time and it was fine. I've run it a few times since with no problems but I can't get the smell out. So, my first question is, what happened? My second is, any suggestions on how to get the odor gone. Thanks! Reply: Try putting two trays of ice and running cold water while the unit is grinding the ice, then toss in a few lemon/lime peels. It probably wasn't "sewage" but smelled like it. The drain line may need to be snaked and cleaned professionally to help prevent this from happening again. e-plumber
Replies to this post
There are none. |
