Re: Basement Shower Drain
Posted by e-plumber on February 11, 2004 at 19:41:32:
In response to Re: Basement Shower Drain
: Replacing shower, there was a thick hard rubber seal between basement floor & old drain. What can I get to replace this. The new shower drain is off a few inches from the old. What would you suggest we do, please. Reply: Depending if the shower drain is off in height or left to right would determine what needs to be done. An experienced plumber will need to look at it and call the shots after seeing it. e-plumber
Replies to this post
There are none. |
