| Posted by Hube on February 11, 2004 at 18:47:20: | |
| In response to Re: reduced water pressure after installing water softener | |
: : : I recently installed a waterboss 700 watersoftener. The water pressure throughout the house has been reduced. I have an Amtrol WX-202 tank and a Pumptrol SquareD class 9013 pressure switch. : : : 1) Is this normal? : : : Thanks.JOE What is the cut-in and cut-out pressures set at now? The instructions are on the inside cover of the 9013 switch. Post back if you need adjustment info....Hube : Its suppose to be 30/50 but the gauge reads 28/48. JOE: By turning the LARGE NUT CW you can raise BOTH the on and off pressures equally. A FULL turn may bump it up to 35/55 or so. A differential of 20 is best.(the small nut ,when turned CW only raises the cut-out pressure. As you have a 20 differential now, do not adjust this small nut. You will have to experiment with various settings, but it is best not to surpass a 40/60 setting. Also, remember that the pressure tank should have 2 lbs less (this is important) air than the "cut-in" setting. This enables the tank to hold the amount of water it was designed to hold. If you have any more questions, no problem. Hube |
| There are none. |
