I had a new well drilled near house- with the wellseal on it above ground. I am regrouping cashwise and am planning on a well shed. Most people in this area (southern oregon coast)just have their shed close to the well leaving enough space to pull pump when eventually it needs it My question is how much space minimum do I need to allow? Also inside the shed should I install a water filtration unit before or after the pressure tank. (just the small particle type filter-whole house.) Does it matter?I realize I am going to need some experienced on site advice/help but this much info will get me started with shed plan. Thanks for any advice--TJ
