| Posted by Hube on February 11, 2004 at 16:02:18: | |
| In response to Re: reduced water pressure after installing water softener | |
: I recently installed a waterboss 700 watersoftener. The water pressure throughout the house has been reduced. I have an Amtrol WX-202 tank and a Pumptrol SquareD class 9013 pressure switch. : 1) Is this normal? : Thanks.JOE What is the cut-in and cut-out pressures set at now? The instructions are on the inside cover of the 9013 switch. Post back if you need adjustment info....Hube |
