| Posted by jimbo on February 11, 2004 at 10:38:40: | |
| In response to 90 degree rise | |
The GPM figures I mentioned earlier (for Bosch) are based on a 90 degree temp. rise. So, if your water comes in at 40 degrees, you could get 130 degree water out at that GPM. If you want it hotter, you must draw fewer GPM; if you draw more GPM, the water won't get as hot. |
| There are none. |
