| Posted by hj on February 10, 2004 at 16:10:51: | |
| In response to Re: Neo Angle Shower Install | |
It's a poor way to install the base, but the filler strip would be anything that would fill the opening so the walls would not be floating over a gap which could crack them if someone were to bump that bottom edge. : It is not a modular install it's a floating base and 2 walls that are glued to the drywall. There is a tab on top of the base that looks like it should go behind the drywall but the instructions say to cut out the drywall and place a filler strip in the void (it's about 3/16"). The instructions do not say if the walls should be painted or not. : : : : I am in the middle of installing a neo angle shower stall. I have hung the green water resistent drywall throughout the bathroom and have a few ???s before continuing. : : : 2. The instructions say to glue a filler strip on the top edge of the base flush with the wall. What is typically used for this filler strip? : : : thanks
| There are none. |
