Re: Leaking drain pipe under old house -- no basement, no crawlspace
Posted by nicktheplumber on February 10, 2004 at 01:09:57:
In response to Re: Leaking drain pipe under old house -- no basement, no crawlspace
If the leak is in a main sewer line (4"), you might look into using the "trenchless" sewer line replacement. Otherwise you have only two options: 1) cut into the building drain before it goes under the inaccessible part of the house and reroute it; or 2) perform a major excavation along the existing line and lay new pipe there.
Replies to this post
There are none. |
