Re: Installing a tub spout
Posted by Don Murray on February 09, 2004 at 23:05:21:
In response to Re: Installing a tub spout
I just installed an American Standard tub shower set. It took two tries to get the 1/2" copper pipe with threaded ends to the correct lenght. It was too long, so I removed one end fitting, shortend it 3/8" and resoldered. The set also has a trim piece that goes between the spout and the tub. The trim piece can compress a little to allow a snug fit and prevents the spout from scratching the tub surface.
Replies to this post
There are none. |
