| Posted by Brian S. on February 09, 2004 at 02:06:38: | |
| In response to Re: Which corner toilet to purchase?? | |
Angelia, If you don't mind the extra 1 3/4" height, consider buying the Patriot Corner toilet in ADA height. I have a regular Patriot toilet in ADA height that I installed in my house over 3 months ago, and it hasn't clogged yet. For some reason, the ADA height toilets seem to work better than the standard height toilets, and I find that true with the Patriot as well. ADA height is also ver comfortable as you don't sit so low on them. Good luck, Brian |
| There are none. |
