| Posted by Notaplumber on February 08, 2004 at 19:26:39: | |
| In response to Re: Lavatory drain into cast iron | |
: That is a good question. But, unfortunately, we would have to know more about it to give an answer. Your drain could be inserted into a slip joint, which would be a simple repair, or soldered into a "solder bushing" which can be somewhat difficult to do the first time you try. And you only get one chance to do it right. : : Need to know how to replace a lavatory drain pipe into a cast iron in the wall. Thanks I think the drain is soldered in. some drains in the house are coming off the cast iron with lead pipe and then to the sink drains with traps |
| There are none. |
