Re: low pressure
Posted by Deb on February 08, 2004 at 17:15:09:
In response to Re: low pressure
: hi everybody,I just removed some galvanized pipes and
: replaced with copper,when I turned on the water supply
: I have very low pressure at my shower/hot side and
: at my kitchen sink hot and cold,but the bathroom
: with shower that has low pressure on the hot side
: the sink has great pressure on both sides,do I have air
: in the system,if so how do I bleeb it out.thanks
You do not have air in the lines. You most likely have debris in the fixtures that broke loose when you were working on those old nasty galvanized lines. Just FYI-galvanized and copper should never be directly connected together. Remove the aerator on the kitchen sink and see if you have pressure. You will probably have to shut off the water, disassemble the shower valve and flush to get the shower working properly again.
Deb
The Pipewench
Replies to this post
There are none.
