| Posted by steve on February 08, 2004 at 11:24:18: | |
| In response to Re: a smell coming from the floor vents ,from basement bathroom | |
: It depends on what the smell is. If it is sewer gas, then it could be coming from the vent which is connected to the rest of the plumbing system. : If it is something else then you have to determine what is causing it before you can correct it. : : we moved in may every thing in the home was redone , now theres a fowl smell coming from the sump pump ...do we need a new one or how do i stop this problem? the vent goes into my living room Did you ever find a fix to your problem? I'm having the same problem with a house I moved into a year ago. |
| There are none. |
