| Posted by jack on February 08, 2004 at 09:14:02: | |
| In response to Re: Kitchen sink vent pipe | |
Thanks Bartman and Greg, Very good advice. It's good to know my concern is validated. If possible, I will try and run the vent through the back of the cabinets. If that doesn't work, (because of the clearance behind the dishwasher, drawers etc) I'll have to rethink. I can't afford to lose any space. Thanks P agree with Bartman, although my house is 30 years old and I found the plumber did indeed drill a 2" hole in my 2x4 stud. I cringed upon this site. That in addition to someone notching the king stud to install another electrical outlet, so I was left with essentially a 1" stud for support...but I digress. Technically, you can bore out 40% of a load-bearing stud, but I wouldn't, so you're right to be concerned. Sometimes, overengineering is wise. : Several options: 1. plumb around the studs, inside the cabinetry; 2. install a cabinet-height half wall/knee wall through which you can bore away; 3. install another interior wall to allow for boring). In my house, I installed another interior wall abutting the original. Of course, options 2 and 3 are if you don't mind losing a little space, but it's worth it if you can. : Good Luck and Have Fun. : Greg : : Hello, : : Thanks for your help
| There are none. |
