Re: Washing machine drains slow
Posted by Gary Swart on February 08, 2004 at 03:37:43:
In response to Re: Washing machine drains slow
First, stop using drain cleaners. The don't work and they create a hazzard for the plumber who ends up working on it. DIY snakes are seldom very effective, they are too small. There could be a problem with the septic tank and/or drain field. If you have not pumped the tank regularly, the drain field could be filled with solids. It could be a clogged drain line. Call a professional to check out the system and correct the problem.
Replies to this post
There are none. |
