| Posted by hj on February 07, 2004 at 20:37:07: | |
| In response to Re: Lavatory drain into cast iron | |
That is a good question. But, unfortunately, we would have to know more about it to give an answer. Your drain could be inserted into a slip joint, which would be a simple repair, or soldered into a "solder bushing" which can be somewhat difficult to do the first time you try. And you only get one chance to do it right. : Need to know how to replace a lavatory drain pipe into a cast iron in the wall. Thanks
