Re: Delta shower control (with anti-scald "feature"
Posted by Deb on February 07, 2004 at 16:55:43:
In response to Re: Delta shower control (with anti-scald "feature"
: I can get only luke warm water at in the shower. How do I adjust it to get hotter? There is a device under the handle that lets the hot turn on only so far. This is generally adjustable and the adjustment procedure is usually obvious. The Delta website should give you more info if you need it. Deb The Pipewench
Replies to this post
There are none. |
