Re: Pea trap
Posted by hj on February 07, 2004 at 16:36:11:
In response to Re: Pea trap
It IS technically accurate, and the only proper way, (even grease interceptors are a form of "P" trap), except for toilets. It is just not the only way if you are just talking about traps in general and their functions.
: HJ,
: True. I often use "P-trap" universally for all trap applications, although technically (as you point out), that is not accurate.
: : Actually, all traps do that, whether "S", "P", "3/4 S", or whatever. The thing that makes a trap a "P" trap is its shape not its function.
: : : To add to HJ's, a P trap (that doesn't leak or dry out) maintains a water seal that prevents sewer gases (and even insects - large American cockroaches) from entering the house via the sewer system.
: : : : What is a pea trap?
Replies to this post
There are none.
