Re: 2 Overflowing Toliets
Posted by hj on February 07, 2004 at 16:27:28:
In response to Re: 2 Overflowing Toliets
You could have two toilets that need to be serviced, or one main line that is becoming obstructed. The stuff put into a toilet a year ago should not have anything to do with your problem.
: In the past(a year or more ago) I had put paper towels & dog waste into one of the toilets. Although I do not do this anymore, that toilet will usually NOT flush - the water always rises near the top (but does not overflow) & has to be plunged constantly. The master bath toliet is now starting to give us trouble . It normally has a very powerful flush, but 3-4 times already in the past 2 weeks it has overflowed & poured toilet water all over the floor. My husband has plunged & used an auger on both toilets to no avail.I've used drain-o & that hasn't helped either. Can these problems in both toilets be related ?... and what to do now? Thanks in advance for your input & help
Replies to this post
There are none.
