Re: HELP ! ! Frozen Sewage Line
Posted by melody hillier on February 07, 2004 at 15:55:12:
In response to Re: HELP ! ! Frozen Sewage Line
it is possible to freeze the sewer line. all you half to do is leave the water run or have a leaky toilet. and the ice will buildup and bingo you have yourself a frozen block of s###. use heat tape on the outside of the pipe. boiling hot water,and salt solution once you get a little bit of a gurgle in the pipes. a 50 foot flat sewer rod works the best for breaking through and if i can do it any one can. good luck. god bless
Replies to this post
There are none. |
