| Posted by rupert on February 07, 2004 at 14:58:58: | |
| In response to Re: leaks when connecting sink stopper pipe to plastic piping | |
: : I have connected the metal pipe that is part of my sink-stopper kit to a new plastic piping "slip joint extension tube." I followed the instructions and did not use any sealent and only tightened the nuts over the washer with my hand, but there is a slight leak. : : I have something called "plumber's goop" and plumber's putty on hand. Would these work as additional sealent between the two pipes or should I be using something stronger or more appropriate. : : I know these packs tell you to just fit the pipes together and tighten things up, but is there a more reliable way to connect these? This is the only place where I am connecting metal to plastic. These are not connected to the trap so I can't imagine that I'd ever want to dismantle this section. : : Thanks, Rupert. : Do not use any kind of sealant--you don't need it. And this will at some point need to be disassembled. Thanks for the advice...one follow-up. So the metal nut and special "flat" washer should screw on to my platic connector piece? Are they usually sold together at the hardware store? The piece I have just says 1 1/4''...I want to make sure that I get the correct piece to use with this piece. -R I just want to make sure that I get the correct |
