| Posted by hj on February 06, 2004 at 22:02:57: | |
| In response to Re: Replacing Tub | |
Plumbers do it all the time, but it requires a lot of experinence to do it correctly. You might want to hire one. : I want to replace my tub, but access underneath tub is nearly impossible. This is no problem in taking out the tub, but attaching the required drain, overflow, and p trap can be a problem once I install the new tub. Any suggestion. sd
| There are none. |
