Re: replacing a toliet water line
Posted by Steven on February 06, 2004 at 19:40:16:
In response to Re: replacing a toliet water line
: If you can see the pipe where the valve connects, you should be able to tell what type of pipe and connection was used. The valve should be easily replaced by either the compression method or screwed into a threaded adapter. I tried to unscrew and it actually squeeze the water line. I'm not sure if it ia a compression or threaded adapter. The whole thing looks like a single piece.
Replies to this post
There are none. |
