| Posted by ED on February 06, 2004 at 16:07:08: | |
| In response to Re: Electric hot water tank installation | |
I got that point right before I hit submit, but I thought if someone else is in a similar situation it would be good to touch on the (electrical)basics, nonetheless. Thanks anyway for calling me on it! hj - you da plumbing master! : He said he is replacing an existing heater, not making a new installation. : : You must run a flexible conduit with the wires inside. That's code. Generally a tank type WH runs : : If you pick up a How-to book on plumbing and or electrical, they can outline and illustrate the process. : : Be VERY CAREFUL if you attempt to work in your Service Panel, the current can and will kill if abused! : : : : : Thanks : : : Soldering will probably give you a tougher time than the wiring. You should have conduit that goes into the top of the tank. There is a small well there with a cover for the wires.
| There are none. |
