Re: replacing a toliet water line
Posted by Gary Swart on February 06, 2004 at 11:57:00:
In response to Re: replacing a toliet water line
If you can see the pipe where the valve connects, you should be able to tell what type of pipe and connection was used. The valve should be easily replaced by either the compression method or screwed into a threaded adapter.
Replies to this post
