| Posted by hj on February 05, 2004 at 21:54:51: | |
| In response to Re: replumb house | |
Since it is a drain line, you would have a bit of a problem running it through the attic, unless you have got a way to make water run up hill. That bit about the attic is what made it sound like a water line. : : What is an "aquilar with attachment"? How the repipe would be done depends on the house and your weather. A local repiper is the only way to determine the best way and the cost. : : : Plumber got a aquilar with attachment in pipe...got stuck in main line. Now need different way to plumb house(40 yr old) around house on outside or through attic-----what info on subject. Thanks : THe plumber was trying to unplug the drain and the metal end of the line got lodge and would not come out It broke inside main line under the cement floor somewhere towrds front.....we need to put in new drain lines from kitchen front/ washing machine in back of house ranch style house? thanks
| There are none. |
