| Posted by hj on February 05, 2004 at 21:51:54: | |
| In response to Re: Electric hot water tank installation | |
He said he is replacing an existing heater, not making a new installation. : You must run a flexible conduit with the wires inside. That's code. Generally a tank type WH runs : If you pick up a How-to book on plumbing and or electrical, they can outline and illustrate the process. : Be VERY CAREFUL if you attempt to work in your Service Panel, the current can and will kill if abused!
: : : Thanks : : Soldering will probably give you a tougher time than the wiring. You should have conduit that goes into the top of the tank. There is a small well there with a cover for the wires.
