Re: typical/std. height for kitchen waste san-tee to trap
Posted by sd2000 on February 05, 2004 at 13:03:27:
In response to Re: typical/std. height for kitchen waste san-tee to trap
No. What size sink works w/ 16in? Is 12in too low? Also, what about pedestal bath sinks?
Thanks alot for your help.
: : Is there a typical height for the san tee which receives the waste from the kitchen trap?
: I generally run them about 16" off the floor. Sinks seem to be getting deeper, so if you are planning a ddep sink and a disposer you may want it a bit lower. Remember, if it is too low, you can always use longer tailpieces. If it is too high, you cut open the wall.
: Have you picked out a sink yet?
: Deb
: The Pipewench
Replies to this post
