| Posted by hj on February 05, 2004 at 08:35:29: | |
| In response to Re: gas pipe sizing pe vs black | |
I assume you are asking for an outside buried gas line. If so, even though the PE may be smoother, the charts are the same, since some PE uses insert fitting which negate any benefits of lower resistance. : Ive seen all the sizing charts for natural gas, and the material of the pipe is never mentioned, or if it is, its always "hard" pipe Is the sizing the same for pe(plastic) piping?
| There are none. |
