| Posted by Vince on February 04, 2004 at 18:59:46: | |
| In response to Re: Gas line to be run thru 2" PVC DWV in slab for island cooktop | |
Can I bring the hotdogs when you "fire it up". This is why plumbers go to plumbin school, so we can be learned about gas and how to run it. I'm sure you have done all the gas goesinto's to see if you can even use what you are hooking up. It's a gas usage thing. Water flowing into a tub while the lav is also on and then someone flushes the toilet, water keeps coming out just at a very reduced rate. That's ok, it just takes longer to fill the toilet, tub, etc. With gas, it's a different story... Hey, it's your place, have fun... |
| There are none. |
