: My pump still pumps water; but it no longer shuts off. When I turn it on the pressure gauge creeps up to 40#, then just stays there and will not go any higher nor kick off. In the past, I think it kicked on at 40# and kicked off at 60#. Since it ran a long time without rest before I discovered this, I thought that maybe the impeller was damaged from heat. So I replaced the impeller but my problem remained. I fiddled around a little with the screws on the pressure switch, but did not really know what I was doing. Any idea on a) what my problem is and b) how to get the pressure switch readjusted to the proper position? Is this a jet (out of well) or a sub pump (in the well)? Is this a Square D pumptrol switch? Let us know and we will advise further. Hube
