: my oil furnace shuts down and have to reset every time, tried cleaning the electroides with alcohol worked for a day. Also when it starts pushes smoke out damper and out of other furnance. I think it might be the nosle,i changed the oil filter a month ago : : any help would be appricated Any time you have to "reset" a furnace, its telling you it needs ADJUSTMENTS. Unless you have the knowledge AND the testing equipment, then you would SAFER to call in a Tech. Oil burners should have a routine "TUNE-UP every year.. Good luck, Hube
