| Posted by Dirkdaddy on February 04, 2004 at 09:02:08: | |
| In response to Re: Sump Pit leak | |
: : Hello, : : (snip) I'm getting about 1 1/2 gal per hr into the pit from ground seepage. : Reply: Also, check see how far you're sump is dumping the water from the house. I had one that was only dumping directly outside the house. Seemed like the same water was going around and around to me. I put the exit into a lawn drain of non-pref. pipe that exited about 20 yards away down a slope and the amount of water draining into the sump decreased by about 80%. Also changed some lawn grading and made some additional lawn drain pipes to divert water in rainstorms b/c of grade problems that sloped towards the house. good luck |
| There are none. |
