| Posted by Bartman on February 03, 2004 at 22:19:09: | |
| In response to Re: Plugged line | |
Gary, Do you have steel pipes? All my old houses have (before I re-did them) and I've always seen more rust/corrosion in hot pipes than in the cold. The higher temps accelerate the oxidation (rust). I would take a good look at your sink's hot water shut off valve. I'm betting that if you replace that your problem will be fixed. |
| There are none. |
