| Posted by Bartman on February 03, 2004 at 02:02:32: | |
| In response to Re: Kitchen sink vent pipe | |
Jack, You can't run 1 1/2" vent pipe through a 2 x 4. The support will be gone. You can run the pipe along the outside of the wall, under the counter/cabinet until you turn into the stud space you will vent up through (that's what I did when I put a big window in over my sink and had to re-locate the vent), OR use an island vent arrangement, see these links: http://www.theplumber.com/vent.html If it were me, I would run a new vent through the roof and eliminate as much horizontal vent run as possible. Nothing says your kitchen vent has to tie into the bathroom vent (mine doesn't).
| There are none. |
