| Posted by Lance on February 03, 2004 at 01:15:56: | |
After removing a friend's toilet, I found that the cast floor flange had been broken. One bolt can still be mounted through the flange, but the other side will not hold a bolt. Someone before has used a flat strip of metal (about 1/2" wide by 4" long) to hold the bolt upright. It doesn't appear that the flat strip will catch the intact edge of the flange very well. Is this repair satisfactory, or should the flange be replaced?
