Re: toilet leaking at the stop valve
Posted by e-plumber on February 02, 2004 at 18:23:30:
In response to Re: toilet leaking at the stop valve
: I have a leak at the supply valve. The toilet is completely disconnected and removed. The valve is turned off, but contiues to drip. Can I possibly fix this without calling a plumber? Reply: The valve needs to be replaced with one that works. For the time being, you can purchase a 3/8" compression cap to seal the valve outlet. Good Luck. e-plumber
Replies to this post
There are none. |
