Sump Pit
Posted by George S. on February 02, 2004 at 16:34:09:
I have a clay tile sump pit that has a 2" hole near the center of the floor, probably due to erosion of the tile. Water is coming into the pit from the ground at the rate of about 2 gal per hr. Is this something that needs to be fixed? I've tried to patch the area with hydraulic cement to no avail,the leak seems to be around the inner rim also.
Replies to this post
There are none.
