| Posted by ED on February 02, 2004 at 14:42:23: | |
| In response to Re: Toilet venting in home | |
All fixtures do need to be vented. You may be able to use Air admittance valve(s). You need to consult a master plumber to be sure. These devices can not be hidden in closed walls. And you need to consider your drain lines sizing, fixtures, and how they are routed, close to the main drain, etc. A number of factors to consider, that you need professional advice. Oh yes, they need to be approved for use in your area too. The best system is still venting-to-roof. : : : How far can a toilet be moved from vent stack, or can i run 1= 3" toilet and 1 1/2 sink with 1 1/2 vent. : : : Thank You Ray : : I have a similar question that I have not been able to find an answer to. In the basement, if I stay close to the main waste stack, can I install a toilet, sink, and shower without adding a separate vent line? It looks to me that if the toilet is within 5 feet I'm OK, but the sink and shower will need some additional venting in a typical layout. Is there any way to avoid the venting...I hate to start hacking into the cast iron stack.
| There are none. |
