Re: American Standard Smart Valve 2000 problems
Posted by Deb on February 02, 2004 at 10:50:08:
In response to Re: American Standard Smart Valve 2000 problems
: I am having problems with the water fill timing on my toilet. It uses a Smart Valve 2000 fill valve, and it won't shut off when the water level reaches the top of the tank. Once the toilet is flushed, it will run (and the water will fun into the overflow tube) for about 2 or 3 minutes, and then it will (finally) shut off. Is there any way to adjust these "smart" valves or has it just gone bad? Thanks in advance for the help These were one of Amer Stds worst products. I would take these out of brand new toilets and throw them away. Then install a Fluidmaster 400A. Deb The Pipewench
Replies to this post
There are none. |
