Re: honeywell aquastat relay L8148J
Posted by e-plumber on February 02, 2004 at 07:48:29:
In response to Re: honeywell aquastat relay L8148J
: i have this model and i have a problem with the wiring. i've got a trouble on where the green and blue wires are supposed to be. where does the "TV" and "T" terminals go? from the 24v transformer, someone used green and blue wires instead of what i think should be the red and white ones. i'm installing a new thermostat and when i looked at the wires, i found out that two red and two white wires are being used, so im not sure which wire with what color goes to which terminal on the new thermostat. thanks for the help. Reply: From here it is impossible to advise you on which color wires need to be connected to which terminals, a plumber experienced in heating or an electrician can read the schematic for the switching relay, trace the wires and wire it in correctly, you don't want to burn out the relay, it is a non-returnable item. Good Luck. e-plumber
Replies to this post
There are none. |
